f4i hohey streetfighter bracket - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=9) +--- Thread: f4i hohey streetfighter bracket (/showthread.php?tid=53789) |
f4i hohey streetfighter bracket - Clutchup - 11-29-2015 whats up guys been reading everywhere trying to figure out if u can upgrade to the big rotor if u got the hohey streetfighter bracket. can you? also found on here somewhere that CB500, CB900 Hornet, XLV600 Transalp rotors fit the F4i, they are 240mm instead of 220mm. can I run one of those rotors with the streetfighter bracket and not have to cut pads? f4i hohey streetfighter bracket - Nappy - 11-30-2015 NDC for big rotor. Streetfighterz bracket for stock rotor. I don't know about the 20mm larger rotors fitting, but I remember everything is tight on those so I would just run the stock rotor. Can you even find SF brackets in stock anywhere? I haven't looked in a long time. f4i hohey streetfighter bracket - Clutchup - 11-30-2015 Yeah I ordered it off of hohey.com and I'm not sure how the power will be on the 4piston and a r6 master I don't want to have my finger getting tired fast. I am using an adaptor with stock piston and it works ok learned circles with it but I need more power. I know the Magura is the easiest pull but I'm Gona try to run my r6 master for now. I also was thinking of running the 4 piston linked with my foot caliper for more power for e cheap. What do you think? Sent from my iPhone using Tapatalk f4i hohey streetfighter bracket - Larse - 12-01-2015 The r6 master with a four piston will have plenty of power, no need to worry. f4i hohey streetfighter bracket - Nappy - 12-01-2015 Yeah, it's a 16mm I believe so like Larse said, no need to link them. f4i hohey streetfighter bracket - Clutchup - 12-01-2015 Ok Sent from my iPhone using Tapatalk f4i hohey streetfighter bracket - Clutchup - 12-01-2015 Thanks Sent from my iPhone using Tapatalk |
