need help! 2005 zx6r 636 snapped front fender off from a wheelie - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: need help! 2005 zx6r 636 snapped front fender off from a wheelie (/showthread.php?tid=53785) |
need help! 2005 zx6r 636 snapped front fender off from a wheelie - scottk - 11-21-2015 2005 zx6r 636....snapped front fender right off coming down from a wheelie. There is not much clearance between my front headlight fairing and fender cause i dropped forks to move clip-ons to the top of tripple. That was working decent (although it was still hitting fender off wheelies). I welded an L shaped bracket from my stunt stay to go under the headlight to give headlight good support. Now i don't have enough clearance and am currently running with no front fender. Well, half of the fender is still there. Prob gonna shorten L-bracket cause i dont wanna move clip-ons. They're perfect on top of the triple. Also i had dirt bars on it and wasn't for me. And by the way, its a 315 Stunt Shop Stay that i just modified. The stay is great, but i think that lowering my forks 2" is main problem. Wanna keep headlight fairing for street, but im beating it up in the lot. Any suggestions? Comments? How is your 06 636 stunt stay and fairing set up? Also i'm looking for a blue front fender. need help! 2005 zx6r 636 snapped front fender off from a wheelie - lee majors - 11-22-2015 what about a hohey top triple? need help! 2005 zx6r 636 snapped front fender off from a wheelie - Larse - 11-23-2015 1: Sick innovations or hohey triple with 1" raised clipons, then you shouldn't hit the fender and your bars will be roughly the same position as now 2: Adjustable clipons 3: Sick innovations clipons under the triple and get used to have the bars lower ![]() Those are some alternatives
need help! 2005 zx6r 636 snapped front fender off from a wheelie - scottk - 11-24-2015 Thanks Majors and Larse. I may have to put clip ons back to original position or go fenderless until i have some spare $. I guess lowering clip ons 2" won't be bad. I may also try making a more precise bracket on my stay. There is a high spot on the fender. If i can avoid the bracket being over top of that, it may give me the room needed. |
