Direct bolt up big rotor for F4i - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: Direct bolt up big rotor for F4i (/showthread.php?tid=53655) |
Direct bolt up big rotor for F4i - dirtysouth - 08-06-2015 Hey guys, Ive done some searching but I keep coming up with I thinks, and Im not sure on year or model of Triumph so Im wondering if anyone can definitively say what rotors are a direct bolt up to a oem f4i rear wheel that are in the 250-265mm range. Thanks. Direct bolt up big rotor for F4i - Larse - 08-14-2015 This is a f4i disc: http://products.moto-master.com/brak...fixed-disc-220 And these are some triumph 255mm discs that fits right on: http://products.moto-master.com/brak...fixed-disc-255 Direct bolt up big rotor for F4i - -william- - 08-20-2015 honestly you might be better off saving for a real big rotor kit, i did the swap a while back, went through the hassle of making brakets for the calipers to finnaly realize that it wasnt making a big difference over stock... Direct bolt up big rotor for F4i - dirtysouth - 08-24-2015 Thanks guys. Yeah I was thinking same on that rotor size so thanks for confirming that. Gonna just spend a lil more and get me a Busa rotor for a NDC bracket. |
