motor swapping 06/07 gsxr 600 to 750 - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: General Category (https://stuntride.the-nags.com/forumdisplay.php?fid=3) +--- Forum: General Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=8) +--- Thread: motor swapping 06/07 gsxr 600 to 750 (/showthread.php?tid=53458) |
motor swapping 06/07 gsxr 600 to 750 - (((Paulie))) - 08-04-2026 Thanks motor swapping 06/07 gsxr 600 to 750 - (((Paulie))) - 02-27-2015 when doing this motor swap is the wireharness the same for both models and all i need is the 750 ECU or do I even need that and can just use the 600 ECU motor swapping 06/07 gsxr 600 to 750 - Graveyard - 03-04-2015 not 100% certain about the harness but you do need the ECU from a 750 for the 750 motor |
