636 Big rotor question - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: 636 Big rotor question (/showthread.php?tid=51371) |
636 Big rotor question - Miked1zzle - 10-17-2013 Ive got the FTI dual quad on my 03 636 and I was just wondering if a big rotor would work with this bracket? And if it does, what rotor would I need? 636 Big rotor question - SQUINTS - 10-17-2013 No.. Not unless you know a good fabricator/welder. Seen johnnyp do it but that's it. Zx11d rotor bolts right up, zx14 rotor needs to be countersunk and slotted to fit but u need a bracket 636 Big rotor question - Miked1zzle - 10-17-2013 What bracket is needed for the big rotor? 636 Big rotor question - SQUINTS - 10-17-2013 Ndc, hohey 636 Big rotor question - Miked1zzle - 10-17-2013 Cool man, thanks for the info. I appreciate it 636 Big rotor question - kirny - 10-17-2013 there is a new bracket out for your bike that uses a front rotor!!! 636 Big rotor question - kirny - 10-17-2013 i will be using it on my zx10 uses 3 r6 four piston monoblock radials |
