Magura 13 lever adjustment - Printable Version
+--- Thread: Magura 13 lever adjustment (/showthread.php?tid=50636)
Magura 13 lever adjustment - Clutchup - 08-20-2013
Hey guys been practicing and my hand seems to small to grip the lever with the adjustment all the way out.now when I make the lever a little closer to my hand I can reach but then the lever hits my knuckles lol (can't win) but I was wondering is there a way to safely bend the lever in just a little? I wana run the adjustment with lever all the way out but reach the end of lever. I herd of using a torch but has anyone done this?
Magura 13 lever adjustment - B-rup - 08-20-2013
Just cut the end off that hits your knuckle?
Yeah but I still can barely reach the lever lol
I'm gona look at it again might just cut the end off and see how it feels
Magura 13 lever adjustment - big ben - 08-20-2013
have you tried stunting on it? when you come up and your hand rotates forward, the lever will sit closer you your finger. also, if the lever is so soft it comes to your other fingers, then by the time the brake gets stiff enough to need significant finger pressure, your finger will already be wrapped around it
Magura 13 lever adjustment - standupnfall - 08-20-2013
Quote Originally Posted by Clutchup
I will send you my cutoff lever and if you like it you can send me your uncut lever.
It is mint but I cut off about 3/4 of an inch.
I am currently using a Brembo so I don't need this right now. When you decide what you like you can send me the uncut one, or mine back. If you detroy them you will owe me a lever.
PM if interested.
Magura 13 lever adjustment - Clutchup - 08-21-2013
Ok I should of tool a pick I cut the end off which sits closer and moved my rsc down the clipon a little now I grab a little father in on the handbrake feels way better and yeah I tried it doing seat standers and was just hard for me to reach... Now it feels better. I'm picky with my controls also first setup stuntbike so I'm learning as I go to setup and feel
Quote Originally Posted by standupnfall
PM if interested.
I appreciate your offer I didn't see it while I was working on my bike but I already cut mine haha
