05 636 build - Printable Version
+--- Thread: 05 636 build (/showthread.php?tid=50494)
05 636 build - drewp812 - 08-10-2013
So I've been on here for a couple months getting info for things I should do to my 636 so far I've found a bunch of good info still trying to figure out things for a handbrake setup this is my first stunt bike I races motocross my whole life and I'm getting into stunt riding I hope I pick it up as well as motocross anyways here is my bike so far any advice on building up my bike would be appreciated
05 636 build - Duane S. - 10-17-2013
my cage sick cage bent after one crash lol and it wasn't that bad of a crash
05 636 build - oemsrt4 - 10-17-2013
All of my atown cages and parts have held up nice and always bolted on/off easily, if your sick cage is toast I would consider atown to replace it. (Link below)
As for the swingarm the 07-08 zx6r bolts up with out having to cut or grind anything but I believe you need to use the 07-08 pivot block and links when you switch also. I would stay with the 05-06 swingarm they don't look that ugly and you know your shock/linkage/chain and everything else will work with it just fine.
05 636 build - drewp812 - 10-21-2013
Ya sick cages suck I wrecked once and it was not bad at all I had to cut it off my bike all the hard wear was bent and whole throttle side of my cage was bent up so bad I couldn't get to the bolt so I ended up cutting it off my bike I also got a sick round bar and it was a biotch to put on I think this time around I'm goin with Atowns cage
05 636 build - drewp812 - 11-18-2013
My cage after one small wreck hard wear is also bent to hell had to cut the cage to even get it off
Finally dented my tank today first one I have ever done
05 636 build - drewp812 - 11-20-2013
Dinted my tank a little more needed more of a lip
05 636 build - burnoutnut - 11-24-2013
MY BET IS you didnt tighten the cage properly down the bottem because SI cages are a top quality cage and it takes a huge huge huge crash to cause that.
05 636 build - kirny - 11-24-2013
Quote Originally Posted by burnoutnut
I hope you are being sarcastic
^^^this I have their clipons and love them
