fuel pump issue but not a fuel pump issue... - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: fuel pump issue but not a fuel pump issue... (/showthread.php?tid=49539) Pages:
fuel pump issue but not a fuel pump issue... - Timchi - 06-07-2013 pump will only prime after i flip the key between off and on about 7-8 times. thot it was the fuel pump so i tried a new one and it still does it. i hooked up a tester light to check the plug that connects to the fuel pump it does the same. only has pwr when i flip the key on and off about 7-8 times then the light flips off. when i do get it started it will stay running and i can hit the kill switch and kill the bike then flip the ks back and it will start as long as i DONT turn the key off. i know its not the fuel pump but a buddy of mine told me it could be the dial or resistor in the ignition for the key. is that correct or have any ideas and how to test it? ![]()
fuel pump issue but not a fuel pump issue... - knowlzy0791 - 06-07-2013 i had an issue quite similar to this, was a loose wire in the ignition, soldered it back on good and it ran like a champ fuel pump issue but not a fuel pump issue... - B-rup - 06-07-2013 Check the kill switch, wires there may be getting a bad connection. Try bypassing kickstand too. Could be numerous things loose, but I'd check those. fuel pump issue but not a fuel pump issue... - Timchi - 06-07-2013 yea im gonna check the wiring on the ignition and the kill switch. i already bypass the kickstand and checked the wire on it fuel pump issue but not a fuel pump issue... - Alex707 - 06-17-2013 sort of having same issue, grounded something out in the ignition connector, now bike will turn over but fuel pump won't prime but it does work when jumped but bike still won't start. going to check the start stop next but anyone else have any ideas this is the second time this has happened miraculously fixed its self last time. fuel pump issue but not a fuel pump issue... - oemsrt4 - 06-17-2013 Could be the fuel pump relay switch also? Dose the fuel pump relay click every time you turn the ignition on and off? If the fuel pump relay is defiantly clicking every time you turn the key on and off then you know you need to start tracking ignition wires and other possibility's. If the fuel pump relay isn't clicking pull the turn signal relay and swap it and try turning it on and off again and see if that solves the problem. fuel pump issue but not a fuel pump issue... - Alex707 - 06-17-2013 Don't think so and can say most likely not. where is the switch. The start switch relay does for sure though fuel pump issue but not a fuel pump issue... - Alex707 - 06-17-2013 Defiantly does not relay is good fuel pump issue but not a fuel pump issue... - Alex707 - 06-17-2013 Defiantly does not ,relay is good fuel pump issue but not a fuel pump issue... - Alex707 - 06-17-2013 Sorry bout the confusion. No the fuel relay doesn't click. The turn signal stuff is long gone. |
