Proper chain slack, and chain maintanece - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: Proper chain slack, and chain maintanece (/showthread.php?tid=48734) Pages:
Proper chain slack, and chain maintanece - B954Fl - 04-20-2013 Whats the perfect amount of slack in the chain cuz I heard its suppose to be pretty loose, like ur suppose to be able to pull the bottom chain down 3-4 widths of a chain? Also should I remove the grease the chain came with from factory and put my belray chain lube or just put it on top of factory chain grease? And how often are u guys cleaning ur chains with aluminum sprockets? I used to clean mine with diesel and put belray on it about every 2 weeks but that was with a steel sprocket. Proper chain slack, and chain maintanece - KYD - 04-20-2013 I use BelRay chain lube as well. resists breakdown really well. But it makes one hell of a mess. Ill put my bike on a rear stand in N and just spin the tire by hand and the rear of the rear sprocket where the teeth begin to mesh into the rollers making sure the lube gets pressed right up in there. and ill spay from the top down into the where the seals are. After i think she's lubed up like a prom date ill spray a solvent of some sort (parts cleaner or dw-40) onto a wrag and wipe the plates and excess lube clean. As for chain slack i normally run 1/2" slack up and 1/2" slack down with bike on the ground. Proper chain slack, and chain maintanece - B954Fl - 04-20-2013 Ya it def makes a mess but all of them do. Just cuz they say fling resistant doesnt mean anything. But try putting it on the stand and putting it in first and just let it spin so chain gets hot then put they belray on it. Ya I never wipe the plates off thts a good idea Proper chain slack, and chain maintanece - vegasrider2005 - 04-20-2013 Use chain wax. Works good when used right. Proper chain slack, and chain maintanece - big ben - 04-20-2013 just realized ive never cleaned, or lubed my chains.......... Proper chain slack, and chain maintanece - hypermike-gba - 04-20-2013 The chain should just be able to touch the bottom of the swing arm with out forcing it. Chain wax has always been my fave Proper chain slack, and chain maintanece - old man roger - 04-20-2013 The important part about adjusting a chain is to make sure it still has some play when the suspension is all the way up and all the way down. If the chain is a little too tight when the bike is just sitting there imagine what happens when you move the suspension all the way through it's travel. Proper chain slack, and chain maintanece - KYD - 04-21-2013 Yeah to tight of a chain will wear out your countershaft bearings in no time which is no bueno. An inch of play is pretty good meause. Think suzukis is a 1.2" for max slack. Proper chain slack, and chain maintanece - B954Fl - 04-21-2013 Ya thats what i heard. It should touch bottom while sitting on the bike bike Proper chain slack, and chain maintanece - B954Fl - 04-21-2013 Ya tht makes sense, im going to have peter hop on the bike and il make sure theres the right amount of play. Do u know how often i should clean this chain though? I member u told me u when u rode dirt ud clean it everytime after riding but am i good just cleaning it once a week cuz I only ride like 1-2 times a week anyway |
