bottoming out bunny hops? - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=9) +--- Thread: bottoming out bunny hops? (/showthread.php?tid=48344) |
bottoming out bunny hops? - 762SPR - 04-01-2013 I noticed a small puddle of oil under my bike, turns out I was bottoming out doing bunny hops and the drain bolt was scraping on the ground and had come loose a little. I'm not really worried about the drain bolt but I don't want to crack my oil pan. Does anyone else have this problem? Should I stiffen up my suspension? I only weigh like 175 so it kind of surprised me this was happening. My buddy said I was getting like 6-8" of air though!
bottoming out bunny hops? - M.F. Mall Cop - 04-01-2013 Happened to me on my f4i. If you havnt already stiffen your rear suspension as much as possible. Maybe it ill help. I ran my rear suspension full hard to get rid of any slop and sag too. bottoming out bunny hops? - 762SPR - 04-01-2013 OK cool. That might take some of the bounce out when I hit the brakes in a wheelie too. Although eventually I would like to be able to do those quick stall hops but I guess I can mess with it later. Is it the inner outer outer adjustment I need to mess with? I guess I could just check the manual... bottoming out bunny hops? - M.F. Mall Cop - 04-01-2013 Stiffer suspension in the rear made everything easier for me. Most people I hear usually say they run full stiff in the back on most bikes. bottoming out bunny hops? - B954Fl - 04-01-2013 Stiffining ur suspension will proly mess up ur bunny hops but better for mostly everything else |
