Impaktech stunt cage installation help - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: Impaktech stunt cage installation help (/showthread.php?tid=48155) |
Impaktech stunt cage installation help - nuttynu - 03-22-2013 Sup everyone, just need some pointers and help and makin sure I'm install it all right. Doing it 0n my 05 Cbr . So this Is what came in. So my questions are, the long threaded rod goes in the engine bolts by the rear set ? And do I remove the castle nut on the right side of the bike by the rear set? & for the mounts where usually the "frame slider goes" the black bolts just screws in and the silver one goes on the other correct..? And what about the provided washer ? Do i need to use em too? So fAr I have it pre set up and almost looks correct but doesn't fully feel secure ..? On the right side , I installed it with the castle but still on. Is this correct ? Any help of advice would help, thanks guys.
Impaktech stunt cage installation help - nuttynu - 03-22-2013 ![]() And for this screw "18" , I'm assuming I use the provided bolt and then use the lock nut once it goes thru the engine frame .? some more pics for verification , took off the engine bolt on the left side, then push out the rod out the right side, now does th castle nut stays, or comes off too? ![]() ![]() ![]() ![]() & what about the spacing for this?? does the provide bolt just goes straight thru with the oem engine spacer and bolts up? ![]() pre set up of what it'll look like
Impaktech stunt cage installation help - nuttynu - 03-22-2013 bump, reserved for more phots to come.... |
