set up questions. - Printable Version
+--- Thread: set up questions. (/showthread.php?tid=47327)
set up questions. - trick - 02-13-2013
Just picked up a stock 05, I am looking for directions on bar set up best options, Im going with motard tires... also want to go with front discs, i was looking at complete front end swaps but dont know if it is needed or worth the investment. any basic help with direction would be great...
set up questions. - KingCrispy - 02-13-2013
I rock stock drum brake in the front... as far as bars go, bbr big bar kit is dope, but really any taller bars would be fine, see if you can try someone you knows 50, and see what you find comfortable. Street tires are definitely the way to go , and are cheap as hell.
set up questions. - tylerstunts - 02-14-2013
it all depends on you. id run stock drums. are u stunting it. and all ya got to really do it is the suspension and get pegs and rhb
set up questions. - Tattooty - 02-15-2013
i've got red baron big bars, 50 stunt pegs and hand brake, and scooter tires. works well for me
set up questions. - SeeBeeAre - 02-22-2013
I don't know about other brands but I had the 50 stunt big bar kit on my 07 and after countless drops they never once bent. You can get the handbrake, stunt peg kit and scooter tires from 50 stunt too, dudes parts are awesome.
set up questions. - Schwasted - 02-22-2013
you can bend the stock bars out to straight to make them way more comfortable to ride than stock. Otherwise I have pro taper bars
