Rsc levers - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=9) +--- Thread: Rsc levers (/showthread.php?tid=46565) |
Rsc levers - ECstunt22 - 01-13-2013 so im deffinitly gunna get me one but i cant make up my mind on shorty or long lever. Anybody tryed bolth of em? I do ride street as much as lot but i dunno if the shorty would be a pain on the street with one finger. Rsc levers - SQUINTS - 01-13-2013 Long lever imo Rsc levers - ECstunt22 - 01-13-2013 ya im startin to lean twards long lever. I just wanna make sure ill have enough space on my clip ons to mount it all the way to the right and still be able to pull with one finger and not have problems. And is there a noticeable difference between ULTIMATE and STANDARD? Rsc levers - tipper13 - 01-13-2013 u can always just cut the long 1 down... i got a short, and wished i woulda got a long Rsc levers - ECstunt22 - 01-13-2013 ya true. Goin with long. Just ordered it Rsc levers - Righteous 1 - 01-13-2013 I'm always down to trade in. Offering 3 lever lengths, always leaves an option for an alternative setup.
Rsc levers - ECstunt22 - 01-13-2013 nice, good to know. Just ordered the long lever. Im sure it will work out but if i dont like it then ill hit ya up. Rsc levers - Righteous 1 - 01-13-2013 rsctakeover@gmail.com ....if you have any questions!
Rsc levers - ECstunt22 - 01-13-2013 thanks! Rsc levers - SIC Nate - 01-13-2013 In my experience, the reason to go with long lever versus short is this: if you have an OEM brake lever for your handbrake then you will need a short lever because you won't be able to mount a clutch lever on the outside of the brake master. If you have aftermarket hand brake lever like brembo or magura or accosato, etc then you can mount the clutch perch on the outside of the brake and use a long lever to take advantage of the extra leverage and extra throw. Both options will position the lever close to the same place, but long lever will be much easier to pull. If you are mounting the perch in the same place (like inside the brake) then there will be no difference in pull. All of this advice is assuming you are a somewhat serious stunt rider that is trying to use clutch and hand brake together. If you have no hand brake then long lever all day! Next, I cannot tell the difference between bushing and needle bearing. The bushing is self lubricating and that's what I use. And by the way if you don't know what this is referring to, it's the pivot point of the lever to the perch. Hope my experience helps |
