rotor break in?? HB - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=9) +--- Thread: rotor break in?? HB (/showthread.php?tid=44006) Pages:
rotor break in?? HB - smokey636 - 10-04-2012 put a brand new busa rotor & pads on my FTI setup & wondering if i have to really break it in b4 my sesh, or just heat it up good an go at it?? lmk plz dont wanna ruin it, my old 1 was pretty warped dont wanna do the same again!! rotor break in?? HB - lee majors - 10-04-2012 id say couple good stops from 55mph would be good. i guess just make sure it locks before you clutch up ![]() can't believe i'm telling you this. your the killer
rotor break in?? HB - smokey636 - 10-04-2012 haha thanks dude, yea i usually just go to like 45 mph a few times and then just ride it, im just trying to see if im right or wrong cause my other1 got fucked but i used it the entire summer tho, it looks good but its warped, like i spun my wheel and it would stop at some point then be free u know, now the new1 rotates steady at all times! rotor break in?? HB - lee majors - 10-04-2012 Quote:
rotor break in?? HB - CRASHDUMMY - 10-04-2012 there is actually a break in so you dont glaze the pads to where they dont work till you take a grinder to them. Its kinda like running heat cycles, not to much at first but enough, let it cool and do it again. i normally jack it up on th kickstand if in back and turn the idle up run it on and off the brake and cycle it a few times like 3 to 5 good times of heat and let cool then heat and then fine.....but thats just my
rotor break in?? HB - Harding Stunts - 10-30-2012 sounds lidget... rotor break in?? HB - navajowalks - 10-30-2012 Quote:
rotor break in?? HB - Dr.MotoKawi - 10-30-2012 Balls out rev limiter chainsaws and you're golden. rotor break in?? HB - tipper13 - 10-30-2012 if it a brand new rotor ill always lightly sand and brakeclean it 1st, but other than that i dont believe that there is any kind of breakin thing rotor break in?? HB - R1wonder - 10-30-2012 Frog podium into bs 5050 right off the bat K go |
