03 636 fti dual 4 piston want to run big rotor - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=9) +--- Thread: 03 636 fti dual 4 piston want to run big rotor (/showthread.php?tid=43994) |
03 636 fti dual 4 piston want to run big rotor - CRASHDUMMY - 08-13-2026 \r\n \r\n anyone anyone .............................. \r\n
03 636 fti dual 4 piston want to run big rotor - SQUINTS - 08-13-2026 \r\n \r\n No way to run big rotor on that FTI bracket. Never understood why that bracket wasn\'t ever offered in big rotor kit. Merlin Machine machined i think 5 of that style bracket set up for a big rotor several years ago... Good luck! \r\n
03 636 fti dual 4 piston want to run big rotor - CRASHDUMMY - 08-13-2026 \r\n \r\n \r\n ok just thought i would ask if anyone new, i dont have any issues but Quote: \r\n
\nthought i would ask..... thanks\r\n 03 636 fti dual 4 piston want to run big rotor - SQUINTS - 08-13-2026 \r\n \r\n \r\n
03 636 fti dual 4 piston want to run big rotor - 762SPR - 08-13-2026 \r\n \r\n \r\n Is there some sort of clearance issue with the rotor?Quote: \r\n
\r\n \r\nIt may not be the ideal setup, but if you\'re willing to do a little grinding on your hub, then you should be able to use one of my 05 06 big rotor adapters and an 08+ busa rear rotor. They are 260mm. Then just throw on some spacers to get the calipers in the right position and you should be good to go. ![]() \r\n \r\nhttp://stuntride.com/vbstunt/showthread.php?t=43630\r\n 03 636 fti dual 4 piston want to run big rotor - SQUINTS - 08-13-2026 \r\n \r\n I think the way this bracket mounts using Honda calipers you can\'t space them bc the bolts are on the side and not on the top like Yamaha/GSXR/Kawi calipers the bracket needs to be larger to allow the rotor clearance. \r\n \r\nI may be misunderstanding you though lol \r\n
03 636 fti dual 4 piston want to run big rotor - 762SPR - 08-13-2026 \r\n \r\n \r\n Oh I get it, so they\'re non radial calipers. Yeah that wouldn\'t work...\r\n
Quote: \r\n
03 636 fti dual 4 piston want to run big rotor - CRASHDUMMY - 10-03-2012 got a 03 636 with fti dual 4 piston setup on it and was wondering is there a big rotor i can run. it makes sense cause of the trimming the pads because its not big enough if so let me know if you have any input on what you can run or how.... thanks |
