Never ending problems 06 zx6r - Printable Version
+--- Thread: Never ending problems 06 zx6r (/showthread.php?tid=43933)
Never ending problems 06 zx6r - 802bouffard - 10-01-2012
So I just rebuilt my trans, ran on Saturday put my new exhaust on Saturday afternoon went to start it battery dead... Put the charger to it then go to start it and the gear that goes to the crank to start it is slipping I have no clue what that could be unless the stator plays and affect with it? I may sound like a moron right now but I've spent like every penny I have just to run into another problem, and the NEW BATTERY I just bought goes dead over night again no idea what it could be
Any suggestions
All fuses are good and wired up correct, checked it over multiple times to try to narrow down the dead battery
Never ending problems 06 zx6r - tin-man - 10-02-2012
Your stator or rectifier could be bad
Never ending problems 06 zx6r - 802bouffard - 10-02-2012
I'm more on the line trying to figure out why the crank gear is moving out towards the stator cover and just free spinning instead of actually cranking the motor
Never ending problems 06 zx6r - Buffalo - 10-04-2012
Do you have a mulitmeter? If so unplug your stator plug and check to see if and of the three stator wires have continuity to ground
