I promise, I searched. 14mm nissin master? - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=9) +--- Thread: I promise, I searched. 14mm nissin master? (/showthread.php?tid=43815) Pages:
I promise, I searched. 14mm nissin master? - KingCrispy - 09-27-2012 Hey guys, I know you're all very into making sure people use the search first, and I tried. I couldnt find the information I'm looking for. All I found was every saying to use a 16x18 brembo. My question is, how are the 14mm nissin master cylinders? I can get a whole handbrake kit from the local dealership for 300 dollars even. My friend had them order it in, and decided he wanted a different set up, so they just want to get rid of it. The only thing, is I'd have to trade or sell the 4 piston adapter probably because its for 03-04 636, and I have an 05. How is the feel of the 14mm master cylinder for a 4 piston caliper? Im tempted to buy it, but I dont want to make a mistake if it wont be any good for street riding. Thanks guys, you're the shit! -Rob I promise, I searched. 14mm nissin master? - rockstar - 09-27-2012 no idea personally... but I would expect a medium to soft feel with a single 4 piston on the rear... in the middle of 13 and 16... I promise, I searched. 14mm nissin master? - KingCrispy - 09-27-2012 I definitely don't want a hard biting hb... being that I will be learning handbrake with it. I'll probably just go for it, and if it sucks, whatever, I'll sell it on ebay or some shit. Anyone else try one? I promise, I searched. 14mm nissin master? - lee majors - 09-27-2012 probly be a bit harder feel than a 16 ![]() you'd probly like a 16 better I promise, I searched. 14mm nissin master? - StrictlyStunt - 09-27-2012 Radial master? What else is in the "kit"? Where was this ordered from? Post pics if you can. 14mm would be softer then a 16, little harder then a 13. I promise, I searched. 14mm nissin master? - StrictlyStunt - 09-27-2012 I have a feeling this is a non radial master. I promise, I searched. 14mm nissin master? - theCOOK - 09-27-2012 If its a non radial your better off just using a flipped 0304 636 master. I believe those are 14mm and you'll save a shit ton of cash. But I think that will be still to soft for streets with a four piston. I promise, I searched. 14mm nissin master? - kirny - 09-27-2012 Quote:
I promise, I searched. 14mm nissin master? - KingCrispy - 09-27-2012 I'll find out today what it is exactly. its just the master, lever, brake line, and dual caliper adapter in the kit. I promise, I searched. 14mm nissin master? - KingCrispy - 09-27-2012 pretty sure this is the same one, but ill stop by honda and find out. http://www.hordpower.com/index.php?m...products_id=17 |
