Will 250f wheels fit on 450f? - Printable Version
+--- Thread: Will 250f wheels fit on 450f? (/showthread.php?tid=43672)
Will 250f wheels fit on 450f? - Cory_4fiddy - 09-21-2012
I found a 08 250f supermoto with marchesini wheels that needs motor work for $1300 and i was wondering if anyone knows if the 250f wheels will fit my 450f
Will 250f wheels fit on 450f? - lucky13 - 09-22-2012
I think so but I would check numbers on em or find someone who sells em add to cart for both models and see if they are the same numbers
Will 250f wheels fit on 450f? - JohnnyP - 09-23-2012
I dont know what brand or model your bike is because you didnt list it.... I might be able to tell you if you gave us that info
What I did when I was trying to find a set of Marchensini rims for my 2012 KX450F, because they didnt make a set for that bike yet. They had a set from a KX250F and I had them send me cad drawings, to check if they fit...It was an older KX250 so everything fit but the front rotor. So I bought them and made my own mounting adapter to replace the one that came with them....
I also looked at the parts fiche for the 2 bikes and compared the hub part numbers...To see if they share the same hubs
Will 250f wheels fit on 450f? - Cory_4fiddy - 09-23-2012
Yeah my bad,i just seen i didn't put what kinda bikes they were. They are both yamahas,ones a wr250f and the other a yz450f. I checked parts numbers and the back wheels are the same,Part numbers are different for the front. IT showing that the collors are different but i can just swap out fork and they should slap right on.
Will 250f wheels fit on 450f? - JohnnyP - 09-24-2012
You might want to check into changing the bearings and making your own collors before buying forks...It might be cheaper and easier...
Marchensini wheels are pretty easy to swap between models because the rotor and sprocket mounts bolt onto the rims and can be swapped out for custom ones...
Thats what I did to make the rims I bought fit my bike
Will 250f wheels fit on 450f? - Cory_4fiddy - 09-24-2012
I picked up the bike yesterday and the wheels fit right onto mine so I'm pretty happy with buying a bike with marchesini wheels for $1500 bucks
Will 250f wheels fit on 450f? - Raf - 09-24-2012
1500 or 1300?
Will 250f wheels fit on 450f? - Cory_4fiddy - 09-25-2012
Originally Posted by Raf
1500 or 1300?
Ended up having to pay 1500 cause someone offered him 1400 so i went ahead and payed him 1500. I was still satisfied with it
Will 250f wheels fit on 450f? - Cory_4fiddy - 10-11-2012
New wheels
Will 250f wheels fit on 450f? - Raf - 10-11-2012
that looks sick
