f4i round bar Tail Cutting? - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: f4i round bar Tail Cutting? (/showthread.php?tid=43428) |
f4i round bar Tail Cutting? - ahenry - 09-13-2012 Ok putting on a si round bar on my f4i. Want to make it look as flush and as clean as possible without snapping the tail. I just need someone to post a picture of theirs that is clean looking and they dont have a problem with it. Just need a reference point. Thanks. f4i round bar Tail Cutting? - Str8JDM - 09-13-2012 guess and test. put the tail fairing on and see where the bar sits. then cut little by little. i find if you cut precise and hit the bar, u still messing up your tail fairing. so give it a little more slack back f4i round bar Tail Cutting? - Str8JDM - 09-13-2012 this is mine btw. i like to show a lil more but still clean
f4i round bar Tail Cutting? - Herz - 09-13-2012 Str8JDM hit the nail on the head. I just pulled everything off. Mounted up the bar loosely and slowly hacked away with a dremel and using a marker to mark potential spots. Just keep putting the tail section back on and off til it fits how you like. Cutting little by little is always the best bet. f4i round bar Tail Cutting? - Jfloryda - 09-17-2012 ![]()
