Gas cap leaking ; dented tank HELP! - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: Gas cap leaking ; dented tank HELP! (/showthread.php?tid=43216) |
Gas cap leaking ; dented tank HELP! - BNasty - 09-07-2012 My dented tank is dented enough down to where it allows gas to leak out of the oem cap's vent. I used another gasket to try and help seal better but that isn't it. Are there any after market gas caps that seal well? Gas cap leaking ; dented tank HELP! - redstar - 09-07-2012 Is it due to the oem cap coming up a little up front? So instead of it sitting flush with the cap the part that actually opens is slanted a little? This topic has been covered a lot of times already. But the solution for most people is to just get a vortex gas cap. Gas cap leaking ; dented tank HELP! - COOLIE - 09-07-2012 That ^ or water weld the shit out of it Gas cap leaking ; dented tank HELP! - BNasty - 09-07-2012 Yea i didnt notice he current thread trending until i posted this. the cap face sits about 1/8th of an inch above the mounting rings surface. the gas leaks thru the vent hole and thru the keyhole/keyhole cover area. Im debating on plugging the keyhole cover area with some sealant and seeing if that helps. I also heard using RTV arouind the ring will keep the gas inside the ring. Gas cap leaking ; dented tank HELP! - lucasstunts - 09-08-2012 clear silicone works for me Gas cap leaking ; dented tank HELP! - Jfloryda - 09-17-2012 true that! got mad leaks and water weld is the shit |
