TIG Welding Thread - Printable Version
+--- Forum: General Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=8)
+--- Thread: TIG Welding Thread (/showthread.php?tid=43037)
TIG Welding Thread - zeus_r6 - 09-01-2012
Just trying to get started in TIG welding for mild steel...any tips/recommendations from the pros?
TIG Welding Thread - Duane S. - 09-02-2012
yes make parts
TIG Welding Thread - Graveyard - 09-04-2012
First off do you have a welder? I can help you get started if you want just pm me.
TIG Welding Thread - big ben - 09-04-2012
fucking tough!
TIG Welding Thread - tin-man - 09-04-2012
Have a few extra tungsten tips prepped and ready to swap into the tip when you first start off your gonna mess those up quite a bit and the foot pedal is weird at first...
TIG Welding Thread - lucky13 - 09-04-2012
At work I run my torch at 20cfh and back up gas is good if you can use it Def have lots of tungston ready get a puddle goin dab some wire in don't force it let it ball up and drop off then move forward a little do the same watch you tube videos too they will help mine is all digital so I set my Welder to max out at 125amps that way half peddle is about 75 amps so you got some to work with either way more or less if you go and max your Welder out at say 300amps half peddle is 150amps... Harder to control... hope it helps
Feel free to pm me and I can throw you my number if you got any questions I can get back to you faster/easier and ask the other welders at my work if I don't know the answer good luck take your time get comfortable first don't rush and start on something relatively thick so you don't melt it all away trying to learn
TIG Welding Thread - COTE - 09-04-2012
Working on starting my own Mobile Welding company
Not sure what anyone else uses but I'm a big miller fan and I currently use an STL150 which is a DC machine only that runs on both 120V and 220V. It's a great machine and a kit costs around $1600. If you have the extra cash a great choice would be the miller dynasty 200 which is about $3000 for the kit but it welds in both AC/DC which means you can weld carbon, stainless and aluminum. It also can run on 120 or 220v, both these machines work with tig and arc(stick) welding.
That's what I use at work a dynasty 250 and 350 bad ass machine
