HELP! 04 636 FI problem - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: HELP! 04 636 FI problem (/showthread.php?tid=42404) |
HELP! 04 636 FI problem - 636stuntlife - 08-10-2012 bare with me.. just started having this problem today took my bike to a spot didnt drop it once but randomly started running like shit and died on me a few times. sometimes when its stuttering the fi will come on And if i dont bump the gas it usually dies and the fi light will stay solid. it seems like if my idle is above 6rpm it runs pretty smooth but if i take a sharp turn it starts studdering and 9 times outa 10 if i do a stoppie itll die when im up.. i thought maybe my tip sensor was messed up so i bypassed it but it has the same problem. Any suggestion???
HELP! 04 636 FI problem - zprt00 - 08-10-2012 Had a similar issue and it turned out to be loose battery terminals haha. it's a long shot, but an easy check. HELP! 04 636 FI problem - Dr.MotoKawi - 08-10-2012 Sounds like some electrical issue as described above, check your wiring for some open or damaged wires. Then try running stock idle of about 15-1700rpm see what happens, also u can pull the fi codes and that may help narrow your search. HELP! 04 636 FI problem - 636stuntlife - 08-10-2012 how do you pull codes on motorcycles? ive been an automotive mechanic for 4 years but havent spent too much time on bikes except for simple shit HELP! 04 636 FI problem - 636stuntlife - 08-10-2012 wires look okay, battery terminals are tight, plugs look okay, cleaned the throttle body, the only thing i can think of is water in the tank. i drained the gas gunna try putting new gas in. any recommended injector cleaner i can throw in? |
