"Burping" oil? - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: "Burping" oil? (/showthread.php?tid=41151) |
"Burping" oil? - Paul - 07-02-2012 I replaced the water pump gasket on my 05 and on the first start up the low oil pressure light is on. what is burping oil and how do i do it? other wise i think i need an oil pump "Burping" oil? - Paul - 07-02-2012 this is on an 05 636 "Burping" oil? - sikgixxer750 - 07-02-2012 Sometimes with aftermarket oil filters an air pocket gets caught in it. I know it happens with frams a lot on the 03 04s. Start the bike and loosed the oil filter a tiny bit until some oil comes out and then tighten it. "Burping" oil? - Paul - 07-02-2012 will it cause there to be low oil light? "Burping" oil? - sikgixxer750 - 07-02-2012 Yea I have seen it where it causes the oil pressure light to stay on. |
