full throttle bog? - Printable Version
+--- Thread: full throttle bog? (/showthread.php?tid=40723)
full throttle bog? - always.anthony - 06-19-2012
Bike seems to do everything fine except from an idle if i give it full throttle it bogs out and almost dies. it probably would die if i help the throttle.
if i blip it before i give it full throttle its fine.
full throttle bog? - Shane K - 06-19-2012
F4i right? My buddy's was just doin that recently..he did a TB sync and it was good
full throttle bog? - zprt00 - 06-19-2012
It's in the 50 section, so I doubt it's an f4i. But since the topic is being raised - my f4i bogged like mad with an aftermarket pipe. Slapped a stock exhaust on it and now it pulls like a train. Maybe that's something to look into.
oh shit, my fault...i'm retarded today , forgive me... saw the title of the thread and his avatar and assumed
full throttle bog? - B-rup - 06-19-2012
Clean out the filter, maybe throw in a new plug.....
full throttle bog? - ADBZ Matt - 06-19-2012
if its not the 50, I would say pull the fuel pump out and blow out the filter on the bottom of it, this is usually the case with bigger FI bikes, not sure about 50's
yeah it's on a 50.
I'll try the filter, but it does have a two brothers exhaust on it. looks pretty free flowing. but not too loud.
swap a plug too that can't hurt it.
full throttle bog? - ScarryJerry - 06-19-2012
clean your carb
full throttle bog? - JCSethro - 06-20-2012
happened to me once on my fiddy. it was bad gas. i just filled it up too. it did it for a week straight, then i emptied all the gas and got new gas from a different station and it was fine. have you tried to run a little choke and see if it revs up fine then? its probably carb/fuel related
full throttle bog? - lucky13 - 06-26-2012
Clean main and pilot with a piece of wire and carb clean
