Accossato 16x18 vs brembo 16x18 - Printable Version
+--- Thread: Accossato 16x18 vs brembo 16x18 (/showthread.php?tid=39855)
Accossato 16x18 vs brembo 16x18 - BrettDstunts - 05-21-2012
How come I never hear anything about accossato HB masters? I need to buy a master and I need info on the accossato HB master. I also got a gift card to hhdesigns and they sell them!
Accossato 16x18 vs brembo 16x18 - =BLEE= - 05-21-2012
Quote Originally Posted by BrettDstunts
Hit up "oemsrt4" on here.he just bought a brembo 16x18 after using a brand brandnew poopstain accoshito 16x18.he constantly was having issues with it getting mushy n goin to the bar..the brembo is working way better..I also run a brembo 16x18 and its perfect..
Accossato 16x18 vs brembo 16x18 - oemsrt4 - 05-21-2012
I would recommend spending the extra 20-25 doll hairs and going with the brembo, I had some issues with mine. The accossato's port where the resi line connects to master seemed really chincy (Thinking it was pulling air into the system) and it had some sort of caulk on the dust cover from them brand new in the box. I would have just got the brembo if I could do it over, The two looked real similar but I just rode all day on the new brembo and it worked flawlessly on the same setup I was fighting with while running the accossato.
"Zeus R6" on here can get you a brembo for a awesome price and he ships fast.
Accossato 16x18 vs brembo 16x18 - Hostility - 05-21-2012
i rock a 16 accossato and it works for me!
Accossato 16x18 vs brembo 16x18 - 321flastunta - 05-21-2012
Can't go work with brembo
Accossato 16x18 vs brembo 16x18 - anarchist35 - 05-21-2012
bremb rcs 15 FTMFW
Accossato 16x18 vs brembo 16x18 - EDUB - 05-21-2012
Im rocking the accosatos front and back and dig em so far
Accossato 16x18 vs brembo 16x18 - masters6RR - 05-22-2012
Running a 19mm Acco on a 8 piston setup, and it's magic.. Brembo 'n Accosato are probably 99.9% the same in regards to performace...
Accossato 16x18 vs brembo 16x18 - Moto-Madness.com - 05-25-2012
Brembo and Accossato are basically the same. Brembo just has slightly tighter tolerances on the internals but other then that they are the same. The Accossato can be completely rebuilt if I remember correctly. Galfer USA is the distributor and will get the rebuild kits last time I checked.
Accossato 16x18 vs brembo 16x18 - zeus_r6 - 05-25-2012
Brembo will always be at the top of the food chain when it comes to brakes
