stupid question on my drz400sm - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Quads / Dirtbikes / Motard / Trials (https://stuntride.the-nags.com/forumdisplay.php?fid=30) +--- Thread: stupid question on my drz400sm (/showthread.php?tid=39633) |
stupid question on my drz400sm - zxstunter - 05-14-2012 i was putting the rear turn signals in a different spot, testing them and they were working fine, then changed my ind and put them back were they were now when i try to see if the right side is blinking the turn signals dont even blink, not even the front ones, i dont know what happend, my tailingt will softly pulsate, along with my speedo. the brake light is dim, but when i push the brake it lights up bright, then when i hit the signal it softly pulsates, its hella weird, one second its working the next its not, not even the front ones thats whats hella weird, i checked all the fuses all good, only thing i have disconected is the wire that goes from the starter to the sienoid, i dought thats the problem, but i dont know this is on a 07 drz400sm stupid question on my drz400sm - *MeatballStunts* - 05-14-2012 check the grounds, if its working but dim thats a sign of a bad ground connection usually. stupid question on my drz400sm - Zuki750 - 05-14-2012 Quote:
stupid question on my drz400sm - *MeatballStunts* - 05-14-2012 check all connections and if you used butt connectors or anything make sure theyre good. I like to solder all my wires for a stronger connection but check your connections and ground and you should find the problem. stupid question on my drz400sm - zxstunter - 05-16-2012 so i put a new starter cable on it (because it was resting on the exhaust) but i went through the wiring and no luck im not sure what the problem is??? front /back blinkers not working and taillight is super dim and when i try the blinkers the taillight still lightly blinking like the blinkers would, same with the speedo.. i just dont get it i was just unplugging and plugging back in the blinkers in the rear, changing the locations, not it fucked everything up lol stupid question on my drz400sm - *MeatballStunts* - 05-16-2012 Tailight is dim because there is a poor connection somewhere most likely the ground. make sure the ground is a good clean connection to the frame. Also try tapping into the tailight ground close to the light and make a new one to see if it brightens up if that works you know thats your problem somewhere. make sure all your connections you plugged back in are correct also. stupid question on my drz400sm - zxstunter - 05-17-2012 went through sodered everything together still no luck , bike dont even fire over now stupid question on my drz400sm - zxstunter - 05-19-2012 so i went through the wiring, soderd everything that was wire connected, i have the tank off and the front head light plastic off as well. i cant seem to find the problem any were. i put on the new cable to the silinoid and the starter still nothing everylight on the bike is hella dim, and when i turn on the parking light the tail light goes bright, i cant figure this out to save my life. now im thinking a part migh be bad, but this is carzy all i was doing was messing with the rear turn signals. please help. i need to get this bike running , the battery is fully charged. i remember before this problem , the bike when starting always seemed like it had a dead battery. it would turn over like the battery was goin to die . sometimes it would just click, i dont know , what part if any do you think is bad |
