Rear Suspension - Printable Version
+--- Thread: Rear Suspension (/showthread.php?tid=38763)
Rear Suspension - Duane S. - 04-18-2012
How do yall run yours? Just curious cause I watch and see some run super soft and some run stiff (which is how I run mine) what are advantages to run it soft and hard? No homo
Rear Suspension - tipper13 - 04-18-2012
i like mine more on the stiffer side. find it a tad bit easier to control the bike.
yea I run it maxed with a half turn back
Rear Suspension - GAMstunts - 04-18-2012
I run mine the same way. I pretty much do that to the front too.
Rear Suspension - krazykyle85 - 04-24-2012
RG3 Suspension dials my front and rear suspension in... for the rear they make it a alittle bit stiffer then stock. reaally helps with every type of wheelie but sucks for "bunnyhops/pro hops". soft rear is the best for catching air of nothing. ha
