how to hotwire a gsxr 600 k6? - Printable Version
+--- Thread: how to hotwire a gsxr 600 k6? (/showthread.php?tid=38554)
how to hotwire a gsxr 600 k6? - beul - 04-12-2012
so guys, first thing that goes tru your heads must be steal.. thief.. blabla..
but no.. i hate my ignitionswitch/key. its under the rear seat, i want to remove it, and do it by a switch. my bike works fine, is not stolen or strange things..
but when i search for info everybody talk like the know how it works, and say that you want to steal a bike or you already did.. i only want to dump my ignitionswitch and use a simple switch..
so does anybody knows the way to fake the tranponder key?
i can tape it on my ecu, but there must be easyer ways.. anybody?
thanks guys!
how to hotwire a gsxr 600 k6? - beul - 04-13-2012
so after reading a lot of stories on different sites and googled a lot.. i found out this!
http://www.gixxer.com/forums/showthr...=213664&page=2
Okay, for those who wanna know.
Start by getting the ignition and right side controls unpluged. On the ignition plug you will have a red, orange, orange w/ yellow tracer, brown, and a grey wire. Now I can't remember all the colors on the right side controls plug, but the only ones that you will be using is orange w/ black tracer and orange w/ white tracer.
After they are unplugged, cut the the ignition harness about 4-5" from the plug. Then cut back the loom on the RS controls harness, find the O/B and O/W wires and cut them about 3" from the plug.
Ok connect R wire from ignition to O/B of RS controls harness(do not use the other half of the O/B wire that goes in to the main harness!! I repeat do not use!!). Then connect O from ignition to O/W from RS controls. Then connect one side of the 100 ohm resistor to the O and O/W connection. Then you have to connect the other half of the O/W back with the the O, O/W, and the resistor connection. If you don't the fuel pump won't kick on!! Then connect the O/Y from the ignition to the other side of the resistor.
The grey and brown wires in the ignition harness are for tail lights/parking lights and front brake switch. I just eliminated them, but you can do as you please.
Hope this helps someone. I couldn't get any help from KWS or Marietta, but I don't blame them. They had good reasons for not helping. I just used a wiring schematic, and took the switch apart and studied it.
__________________
how to hotwire a gsxr 600 k6? - motopsycho231 - 04-13-2012
so you got it all done up? How'd it go?
how to hotwire a gsxr 600 k6? - #TMNT - 04-13-2012
thief lol
how to hotwire a gsxr 600 k6? - da Liks - 04-14-2012
ok genious. i'll try and draw it out when i get back tomorrow and see if there's a way i can do it and still undo it.
how to hotwire a gsxr 600 k6? - beul - 04-14-2012
i didnt do anything to the gixxer.. gonna change the front tire for tommorow session..
first things first
how to hotwire a gsxr 600 k6? - da Liks - 04-16-2012
i'm wondering of you can do this without cutting the ignition harnass.. what do you think?
how to hotwire a gsxr 600 k6? - da Liks - 04-18-2012
so i disconnected my ignition and rightside controls. funny thing is, the ignition has 2 (!!) plugs, not 1.. check it out, 2 two on the left are for ignition, the 1 on the right is the rightside controls.
how to hotwire a gsxr 600 k6? - SIC Nate - 04-19-2012
I didn't read the thread on the other site, but I have put remote start on my gsxr's inthe past and there is a (i think orange) wire that runs through a resistor in the ignition to prevent simple hot wiring. If you unplug the ignition and use a multimeter to test impedance between a large gage main power wire and a small gage resistor input to the ecu, you can read the resistor value. Then buy resistors (avail at any radio shack) of the value that was read to wire inline on this ecu wire.
how to hotwire a gsxr 600 k6? - da Liks - 04-19-2012
ok, but if we bring into the comparison that our european models have an immobiliser in the key and 2 plugs instead of one? does that alter the mod?
