How do I connect led lights to my car? - Printable Version
+--- Forum: Motorcycle News and Press Releases (https://stuntride.the-nags.com/forumdisplay.php?fid=75)
+--- Thread: How do I connect led lights to my car? (/showthread.php?tid=35474)
How do I connect led lights to my car? - AnthonyMartello - 01-14-2012
Hello friends,
I need to put led lights on the exterior of my car, but they need to be connected to a power source. How do I connect it to the battery? I'm trying to put lights under the door handle, on the tailpipe, on the license plate, and on the side view mirrors.
Thanks
Anthony
How do I connect led lights to my car? - Drakstunt - 01-14-2012
Run the positive and negative from the battery to behind the dash and there you can have the switch and relay split to each light. The doors are tricky since you have to put wires through the rubber boots, but you can do it. For the tailpipe and license place just run the wires under the door sills to the back and then down through any hole by the taillights to your leds.
How do I connect led lights to my car? - $Evan$ - 01-15-2012
Go to vato zone pick up sme lights they normally have wiring diagrams too
How do I connect led lights to my car? - AnthonyMartello - 01-21-2012
Hello friends,
Many thanks for sharing your information, Really I am highly appreciated.
Best Regards
Anthony
How do I connect led lights to my car? - lee majors - 01-23-2012
cut the red wire.
not the blue one.
