brake/fork issue - Printable Version
+--- Thread: brake/fork issue (/showthread.php?tid=32882)
brake/fork issue - jack cooke - 08-12-2026
\r\n \r\n front axel is coming loose just happened to my buddy last time at the lot. check that.\r\n
brake/fork issue - BirDMaN420 - 08-12-2026
\r\n \r\n If it isnt the above, your left fork could be leaking oil and is running low. The less oil, the easier for the fork to compress. U could test it by taking the front wheel off and pulling each fork up and see if the 1 is much easier\r\n
\r\n Originally Posted by BirDMaN420\r\n View Post\r\n
I beleive he is asking about his 50 and if so there is no oil just spring and grease. it either your axel is a little loose or maybe the your fork leg is sitting a little crooked. check the axel and if its not loose at all take the front wheel off and see if your fork legs are crooked or sitting straight.\r\n
brake/fork issue - tylerstunts - 08-12-2026
\r\n \r\n had same problem gota tighting up the front axle.\r\n
\r\n Originally Posted by jack cooke\r\n View Post\r\n
No oil in the forks! =O WTF! That\'s fucked up! Havent ever had a 50, but all the 110/125 pit bikes i\'ve owned (normal and upside down forks) have all had normal forks with oil in them lol. How do those forks hold up?\r\n
brake/fork issue - JimG - 08-12-2026
\r\n \r\n your fork bushings gone its common on the brake side\r\n
\r\n \r\n get derlin bushings and problem solved..\r\n
brake/fork issue - lucky13 - 08-12-2026
\r\n \r\n yeah get a set of 50 stunt delrin bushings ... a must if you wanna try doin stoppies on thoes little things\r\n
brake/fork issue - stunt305 - 10-17-2011
idk if its normal and im just realizing it now or if ive got a fixable problem but when i grab my front brake at any pressure my wheel violently jerks sideways to the brake side....anyone?
