best fork setting for stoppies on 03 636 - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: best fork setting for stoppies on 03 636 (/showthread.php?tid=31524) Pages:
best fork setting for stoppies on 03 636 - zucca636 - 09-06-2011 What are the best settings for the upper and lower fork screws to do the best stoppies...just wondering what some people out there have them set at best fork setting for stoppies on 03 636 - WiseGuy - 09-06-2011 get the 05-09 front fork set up... best fork setting for stoppies on 03 636 - $Evan$ - 09-06-2011 there is none best fork setting for stoppies on 03 636 - da Liks - 09-06-2011 it's trial and error.. i like mine with stiff rebound. best fork setting for stoppies on 03 636 - thePMFG - 09-16-2011 yea I prefer stiffer rebound too, just seems to feel a lot more responsive.
best fork setting for stoppies on 03 636 - mattducati08 - 09-17-2011 i just put 15wt fork oil in..throw in an extra 10cc's...super stable and less break use to snap it up best fork setting for stoppies on 03 636 - mart211 - 04-29-2013 I thought i had my rebound on hard too but seems i was tuning the compression instead lol. I have rebound on soft(the top screw) and compression on hard(bottom screw) and preload on hard. What are everyone else running? best fork setting for stoppies on 03 636 - old man roger - 04-29-2013 That's pretty much where I start too. Making the air gap smaller, by adding the extra fluid, is like having stiffer springs with out having to re valve. As far as the other settings, I like the rebound as slow as possible. I like my compression just fast enough to not dive so fast that it shocks the tire. I set my preload just stiff enough so it doesn't speed up the rebound. best fork setting for stoppies on 03 636 - pray4butter - 04-29-2013 I was wondering the same thing yesterday. I bought some 08 zx6r forks over the winter from a dealer who claimed to have just changed out oil/seals, but they were bottoming out super easy on my first time out yesterday. I tightened that nut on the top of the fork tubes all the way down and then backed it out one turn, I also did the same with the smaller nipple inside that nut that you tighten with a flat head screw driver. I did the same for the bottom of the fork tubes too and they still bottom out super easy, just braking hard not even getting the back wheel off the ground. A friend was telling me I need thicker oil? best fork setting for stoppies on 03 636 - hypermike-gba - 04-29-2013 15w Really? I use 10w with stock level and my shit is alway stiff. I could not imagin 15w and 10cc more. Might as well have a solid suspention lol |
