chevy 5.3 l engine help needed - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: General Category (https://stuntride.the-nags.com/forumdisplay.php?fid=3) +--- Forum: Automotive (https://stuntride.the-nags.com/forumdisplay.php?fid=53) +--- Thread: chevy 5.3 l engine help needed (/showthread.php?tid=30761) Pages:
chevy 5.3 l engine help needed - maverickxp - 08-14-2011 OK so the other day I lost all oil pressure in my motor and the valves started ticking. I replaced the oil pump and o ring and ran 1qt marvel mystery oil in it. The ticking has now subsided but the low oil pressure light is still on. Any ideas. I'm not sure if its just the sensor since that activates the light and may be bad or if I spun can bearing or clogged oil galley. Any thoughts would be great. Thanks guys chevy 5.3 l engine help needed - beardo - 08-14-2011 Get a manual gauge. chevy 5.3 l engine help needed - xxxfrankenstein406 - 08-14-2011 +1 reset ecu maybe? chevy 5.3 l engine help needed - anarchist35 - 08-14-2011 u should definitely test your oil pressure, and go from there. chevy 5.3 l engine help needed - maverickxp - 08-15-2011 I have 60 psi at the filter bit can't get a tester on at the sending unit due to the location being back against the firewall. chevy 5.3 l engine help needed - beardo - 08-15-2011 Change the sending unit, see if that fixes it. I dont understand why if it was just the sender..... Why would the lifters get noisy?? 60 psi is more than enouph chevy 5.3 l engine help needed - maverickxp - 08-15-2011 Well I think the pump went bad. It had Its of play. I now have a new pump so hence the Psi but I'm thinking that I may have loosened some shit in the motor or something Because this all started the day after I ran some Lucas oil in my motor. Which may have loosened some sludge or something. chevy 5.3 l engine help needed - xxxfrankenstein406 - 08-15-2011 Lucas oil makes your oil thicker I'm pretty sure. chevy 5.3 l engine help needed - beardo - 08-15-2011 Sender might be clogged chevy 5.3 l engine help needed - maverickxp - 08-15-2011 Yes it does bit it also cleans all the crap out of ur motor. So I think that's what happened. I'm gunna pick up a new sensor and see if that fixes it |
