(636) 05 rear wheel on 03 swingarm - Printable Version
+--- Thread: (636) 05 rear wheel on 03 swingarm (/showthread.php?tid=29280)
(636) 05 rear wheel on 03 swingarm - Villa76 - 06-30-2011
Use the 05 spacers and axle or use the 03 hardware? Have both. Thanks in advance.
(636) 05 rear wheel on 03 swingarm - WiseGuy - 06-30-2011
i jus had a thread about converting to 05-06 wheels and front end... 05 spacers with 03 swingarm, if u are running an FTI bracket it wont line up tho...
(636) 05 rear wheel on 03 swingarm - loogie - 06-30-2011
you need e HHD spacer kit or make your own.
thats what the spacer kit does...
thanks loogie!
Figures. I do have the fti dual cal.
i know i had the same moment as u... we r gonna have to find some of those spacers, or get some 06 swingarms...
(636) 05 rear wheel on 03 swingarm - old man roger - 06-30-2011
you use both on the right side , one big spacer one small spacer and if you have the fti caliper mount you can make a spacer to move the rotor over to the caliper
(636) 05 rear wheel on 03 swingarm - nj636 - 06-30-2011
or get to cuttin
(636) 05 rear wheel on 03 swingarm - GIL with 1 L - 07-01-2011
Trade ya for 05 swingarm
