motor problem. need help - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: 50 stunts (https://stuntride.the-nags.com/forumdisplay.php?fid=21) +--- Thread: motor problem. need help (/showthread.php?tid=29226) Pages:
motor problem. need help - *MeatballStunts* - 06-28-2011 I just picked up another fiddy for 100 bucks off a friend cause he says the motor isi blown or something and its sat for the last 2 years. So Im gonna see if i can get this motor running if i can. I cleaned the carb new gas new oil and i am kicking it over it has compression new spark plug but when i checked the oil it looks like gas is making its way to the crankcase and mixing with the oil. So what would cause this bad rings or a gasket? The motor has an 88 kit on it. So what should be my next step when taking it apart or do they make a cheap rebuild kit for this? motor problem. need help - iVorTec - 06-29-2011 my guess is bad rings...but im no mechanic...just my .02 motor problem. need help - *MeatballStunts* - 06-29-2011 anyone have any suggestions? motor problem. need help - BAKER - 06-29-2011 If your getting alot of gas in the oil I would say its a carb issue. Carb is possibly flooding the cylinder which is causing gas in the crank case. motor problem. need help - *MeatballStunts* - 06-29-2011 Im gonna pull the carb off tonight and take a look at it. Im not sure what exactly to look for when i take it apart but i know how to clean it out and check the jets and everything to make sure they arent clogged. what would cause the carb to flood the cylinder? I dont even know what carb is on this motor cause apparently it has an 88 kit on it but i dont know if the carb is stock or changed. motor problem. need help - *MeatballStunts* - 06-29-2011 anyone else ever see a problem like this? motor problem. need help - BAKER - 06-29-2011 Check the float setting and needle and seat. motor problem. need help - 600rrupncomer - 06-30-2011 bad crank seals? motor problem. need help - 32ndKnockout - 06-30-2011 There's a few things to consider. If it has good compression at room temperature, your rings probably aren't bad, but there might be some scoring on the cylinder walls. I can think of 3 places the fuel could get into the case: 1. past the rings 2. through the intake valve guide 3. through the head gasket between the cylinder and cam chain. I'd start by checking the carb to see if it's flooding the cylinder by removing it from the bike while keeping the fuel line hooked up. hold it the same way it sits on the motor and turn the petcock on to see if fuel starts dumping out of it before you adjust anything. If that IS your problem, then start adjusting... if not, then move onto other possibilities. motor problem. need help - *MeatballStunts* - 06-30-2011 I got the carb off and it was all clogged up and I guess from sitting over years the gas corroded or something in it cause it was filled with a white powder. Jet needle everything was all clogged up. Got it all cleaned and got the motor to fire up. SO now I just gotta get it running better and see how it runs. But I got the motor to fire up so Im on a good start. |
