are the 2004 636 motor a interfance motor - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=9) +--- Thread: are the 2004 636 motor a interfance motor (/showthread.php?tid=28565) |
are the 2004 636 motor a interfance motor - big will - 06-10-2011 need to no if the timing chain breaks is it going to bent the valves are the 2004 636 motor a interfance motor - maverickxp - 06-10-2011 yes it will. even being off 1 tooth will bend valves. i found out the hard way are the 2004 636 motor a interfance motor - Bortner - 06-10-2011 Not all the time depends on the circumstance but most of the time yes are the 2004 636 motor a interfance motor - richd3000 - 06-11-2011 i ran mine with 1 tooth off for over a year... just ran funny, hada bad stutter about 3-4 grand. now its back in time and runs smooth n strong off idle.. i turned motor by hand before starting and no problem. they will run with a cam one tooth off. |
