Why does this 50 look weird!? - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: 50 stunts (https://stuntride.the-nags.com/forumdisplay.php?fid=21) +--- Thread: Why does this 50 look weird!? (/showthread.php?tid=27627) Pages:
Why does this 50 look weird!? - Sogan88 - 05-14-2011 ![]() ![]() Found this 50 on craiglist and everything looks good except for some reason the forks look weird to me? He says they are BBR forks but they look super long and out of proportion or something? I wanna stunt it but idk if longer front fork will be a problem Why does this 50 look weird!? - WHEELIE - 05-14-2011 It's Because He's got it on that bucket.... Why does this 50 look weird!? - Wheeeelies! - 05-14-2011 different front end Why does this 50 look weird!? - Sogan88 - 05-14-2011 lol I mean I knew that was throwing it off a little but i swear my old fiddy didnt look this off Why does this 50 look weird!? - Wheeeelies! - 05-14-2011 idk it looks raked out like a chopper
Why does this 50 look weird!? - oemsrt4 - 05-14-2011 If you go to look at this make sure you check the neck of the frame out real good. on my 50 the stock frame was starting to buckle little by little. I used to measure with how many fingers I could fit between the skid plate and the front tire. after a month I could fit my whole hand in there and decided to get the billet ware cradle frame. ![]() It almost looks like the frame is starting to buckle hence the chopper/raked out look.
Why does this 50 look weird!? - WHEELIE - 05-14-2011 Good Call...
Why does this 50 look weird!? - Sogan88 - 05-14-2011 If you go to look at this make sure you check the neck of the frame out real good. on my 50 the stock frame was starting to buckle little by little. I used to measure with how many fingers I could fit between the skid plate and the front tire. after a month I could fit my whole hand in there and decided to get the billet ware cradle frame. It almost looks like the frame is starting to buckle hence the chopper/raked out look. Why does this 50 look weird!? - B-Dub - 05-14-2011 The angle does look off. And the forks look long Why does this 50 look weird!? - clutchitup314 - 05-15-2011 You act like your gonna be using the front wheel alot. |
