i wanna try and design my own wrap - Printable Version
+--- Forum: Artwork (https://stuntride.the-nags.com/forumdisplay.php?fid=41)
+--- Thread: i wanna try and design my own wrap (/showthread.php?tid=26755)
i wanna try and design my own wrap - Paul - 04-23-2011
i have photoshop cs5... do i need anything else? the print place said i need a vector file does photoshop save in vector form?
i wanna try and design my own wrap - DOKE - 04-23-2011
Save it as an illustrator file. Then it will be vector upon output. If that's not what you are asking then give me more details.
i wanna try and design my own wrap - StrictlyStunt - 04-23-2011
save as .psd or .eps they should be able to take it from there.
Isn't that similar?
Originally Posted by DOKE
Isn't that similar?
yeah, just a bit more universal depending on which programs the print shop is using. Saving via photoshop that is
thanks fella's..... when i finally figure it all out and get something decent i wanna try to send it down to the shop as complete as possible to keep to keep any design fees down
i wanna try and design my own wrap - RUTHLESS RAH - 04-23-2011
can u make me a design while your at it...thanx
i wanna try and design my own wrap - inolen - 04-23-2011
That doesn't automatically make it vectorized.
Paul, it's not about saving in some vector format, it's about designing in a vector format.
Vectorized graphics is a concept, where you use geometric primitives to draw as opposed to just setting the color of raw pixels. Therefore, since everything is described through a series of mathematical equations as opposed to a static set of pixels, you can easily scale the drawing to an infinite resolution.
So, Photoshop has some ability to work with vector graphics, but Illustrator is the tool you're looking to use here.
illustrator like I said above
do it urself.... didnt even vote for ur homey when it came to the stb thread!
