01 F4i ECU Reset? - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: 01 F4i ECU Reset? (/showthread.php?tid=26627) |
01 F4i ECU Reset? - WillD - 08-13-2026 \r\n \r\n Your stock ecu, should make adjustments in your air fuel ratio up to a 10% change. I have never heard of a reset for stock ecu\'s, I could be wrong though. If you just have exhaust and maybe an air filter, you should be fine, worst ive ever seen was a bike running slightly lean, but it had more mods than just a pipe... download the service manual, tons of links around here to get one...\r\n 01 F4i ECU Reset? - M.F. Mall Cop - 04-20-2011 Does anyone know how to reset the ECU on an 01 F4i. Just got an exhaust system and figured it might be good to reset everything back. |
