tube or tubeless - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Quads / Dirtbikes / Motard / Trials (https://stuntride.the-nags.com/forumdisplay.php?fid=30) +--- Thread: tube or tubeless (/showthread.php?tid=26623) |
tube or tubeless - sitdownsteve - 04-20-2011 Who's running what, have you ran both, what's better and how much PSI are you going? I run 35-40 on my 636 and would assume I would run hi on the tard just wanted to know which is a better route tube or tubeless - Righteous 1 - 04-20-2011 Tube tires can be a bitch to change.....pinch the tube with your tool.....gotta do it all over again. Tube tires are more envolved to balance......and they weigh more. I like tubeless.
tube or tubeless - Righteous 1 - 04-20-2011 .......but....a LOT of motard wheels require tubes! Like mine!
tube or tubeless - Teach - 04-21-2011 tubeless for sure...hit up woody's wheel works in denver not too hard to do yourself though. i've got heavy duty spokes and tubeless rims and they are pretty much indestructable tube or tubeless - Stubbz63 - 04-21-2011 i run a tubeless tire with a tube in it as almost everyone does. dont think youd wanna run pressure that high tho or why you would want to. i run mine 25-30 in rear but like 27 in front tube or tubeless - BigJasonRR - 04-22-2011 There is a write-up on Supermotojunkies.com about how to convert your tube wheels to "tubelss" for under $10 (or some shit like that). Check it out. I'm still running tubes. tube or tubeless - Brandon L - 04-27-2011 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() tube or tubeless - Brandon L - 04-27-2011 its nice to dream, but right now im just running stock wheels, with tubes, and one size bigger tube-less tires. however......... i would love me some MARCHESINI they would be sick!!!!!!!![]() ![]() |
