F4i Tip over Bypass - Printable Version
+--- Thread: F4i Tip over Bypass (/showthread.php?tid=26571)
F4i Tip over Bypass - Sunner - 04-19-2011
Ok so I did the by pass, what do you guys do with all that extra harness?? I don't just want to tie it off somewhere, I was wondering if there was a place to bypass it at the main harness plug but couldn't find anything
F4i Tip over Bypass - *Gswitch33 - 04-19-2011
I bypassed mine at the main and then salvaged the upper harness to accommodate the blinkers and lights.
Ill see if I can put some pics up tomorrow to show ya if noone else beats me to it.
Is that scotch tape? Go get some solder or something. I wouldnt trust scotch tape unless your just mocking it up at the moment.
F4i Tip over Bypass - Chambo - 04-19-2011
I just did mine at the main plug and got rid of the rest of the wiring. Im not running head lights or anything
Yeah that tape is just a temp fix, thats what I was trying to find, how to do it from the main plug but every thread I searched showed how to do it from the tip sensor. I do plan on running a Acerbis Headlight though, will that be effected if I do it from the main plug like I want to?
F4i Tip over Bypass - PalermoCorey90 - 04-19-2011
hmmm ill see i can find any pics from when i did mine.
Thanks guys, I appreciate it.
From the main plug i just stuck a piece of safety wire into the green and red wire and then taped the whole plug up. That might be a problem if ur trying to run a head light. I have seen people use jumpers right behind that main plug to connect them.
http://www.stuntlife.com/forums/443-...er-sensor.html
F4i Tip over Bypass - Sunner - 04-20-2011
Never mind, I just sort of wraped it up in between the tank and airbox and frame, its pretty hidden.
