gauge cluster mount? - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=9) +--- Thread: gauge cluster mount? (/showthread.php?tid=25782) Pages:
gauge cluster mount? - Blizzle - 04-02-2011 Anybody have some ideas how to build your own gauge cluster mount or have any pics of the HollywoodStuntparts mount? I want to mount it on the cross bar of the frame. I currently have it ziptied to the cage. Like this!! gauge cluster mount? - CHILI - 04-02-2011 You can mount it just like that using zip ties. That's how mine is. I did like 3 zip ties just barely loose on the frame, then i put zip ties around the gauges then through the zip ties on the frame. And when i need the guages off i just cut the ones off the guage and leave the ones on the frame attached.
gauge cluster mount? - Blizzle - 04-03-2011 Quote:
gauge cluster mount? - EzMac - 04-03-2011 Quote:
http://stuntride.com/vbstunt/showthr...t=7572&page=17 gauge cluster mount? - CHILI - 04-03-2011 Quote:
gauge cluster mount? - Graveyard - 04-03-2011 I stuffed mine in the right airbox hole and ziped it to the cross bar, looks clean and didn't cost a thing! gauge cluster mount? - *Gswitch33 - 04-04-2011 Quote:
gauge cluster mount? - YSRRider - 04-04-2011 what happened to hollywood stunt parts? gauge cluster mount? - CHILI - 04-04-2011 He shut down a while back gauge cluster mount? - StrictlyStunt - 04-04-2011 when my bike was SF i mounted my gauges to the frame via zip tie
