cracked head - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=9) +--- Thread: cracked head (/showthread.php?tid=24597) |
cracked head - Dstunts - 03-07-2011 Anyone had this happen before? I spoke to an engineering shop that said they could weld it but what do you guys think, will it hold up through future drops?
cracked head - old man roger - 03-07-2011 seen it on a bunch of f4i's not on a 636 , i would get another motor cracked head - StuntBikeJake - 03-07-2011 Austin913 did the same thing to his 636 cracked head - KYLE - 03-07-2011 Seen it happen to several 636's, just put some honda-bond on it! cracked head - old man roger - 03-07-2011 that sucks , if it didnt go right into the center of the cam seat i would say give welding it a try but nah i would just find a used motor if it were mine cracked head - jerz4sures - 03-07-2011 did this to my 636..i also wanted to weld mine but mine was cracked too bad around the corner to weld, i would guess yours is to. i bought a used head on ebay and replaced it.. good luck (and i seen people replace heads without droping the motor but not sure on 636 cause mine was already out) cracked head - jerz4sures - 03-07-2011 what kind of cage? cracked head - Dstunts - 03-07-2011 damm i was hoping i could get away with the $50 weld.. And yep its cracked up around the corner aswell, Im runnin a tygershark cage. Is there anythin that could prevent this sort of thing from happening? or is just too many hard drops? cracked head - Crazy Justin - 03-07-2011 that happened on my 2 of my f4i motors. the first one i got welded and it cracked right open the first day riding it again. It was also welded by fastrack whos a reputable welder here in phx, didnt matter. get a new motor cracked head - old man roger - 03-07-2011 i think one wheel neal broke a couple f4i motors like this to , i had no idea so many people broke 636's like this |
