Need help on stoppies - Printable Version
+--- Thread: Need help on stoppies (/showthread.php?tid=23160)
Need help on stoppies - zinomori - 01-31-2011
I have been trying to learn stoppie on my Honda CBR 600RR. I can come to a stop and do a stoppie, but not really ride it out. I don't have any problem with the rear tire, it comes up fairly easy, but the front one always slides out. Just wondering is there anything I need to do with tire pressure? BTW I am running around 35psi. How much pressure do you put in the front and rear tires for doing stoppie?
Thanks..
Need help on stoppies - StuntBikeJake - 01-31-2011
What kind of tire?
The proper tire will help alot..
Also what are your suspension settings set up like? Hard? Soft? Compression? Rebound? Preload?
Quote Originally Posted by Outlaw_FTP
What kind of tire?
I don't know much about suspension settings. Everything is factory installed.
Need help on stoppies - wr290x - 01-31-2011
35 is a good psi you dont want a low tire psi because trying to do 180 or control it is alot harder...when yo go into your endo pinch your knees lift u ass up to help pull bike up but only 1/4 of an inch or so and square of you shoulders and always look foward...t- neck tought me years ago behind a whare in o town been killn them ever since...get a pilot power 2ct best grip tire
Need help on stoppies - da Liks - 01-31-2011
Quote Originally Posted by zinomori
Thanks..
what kind of tire!!! how old!!! how cold is it where you're at! how clean is the surface you wanna roll on!!
answer those first..
Quote Originally Posted by da Liks
Any advice this guy gives.. take it!!! He knows his stuff...
Heal up buddy!
thank you sir!
Need help on stoppies - nags - 01-31-2011
Take it to the grip.
Need help on stoppies - SDFKILLZ - 01-31-2011
32psi, pilot power will grip to a wet turd in 30 degree weather.
Need help on stoppies - $Evan$ - 01-31-2011
that avitar is sweet
