Big Rotor Kit Question - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: Big Rotor Kit Question (/showthread.php?tid=21698) Pages:
Big Rotor Kit Question - ADBZ Matt - 12-20-2010 I have an HHD Dual caliper with a 4 piston adaptor for my HB, stock FB... I am wanting to upgrade to the big rotor kit... do I need to buy another bracket for my 4 piston or just a bracket to space my stock footbrake caliper? or Both? And a large rotor ofcourse... If anyone has one laying around that they want to get rid of PM me... Just want a bot more feel on the brakes... thanks in advance -Matt Big Rotor Kit Question - Raider - 12-20-2010 If you want more feeling in the fb go up to a 4-piston footbrake.... it's magical. I have WASTED ankles and had a real hard time modulating the stock hard fb pedal and after I went to the 4-piston it gave the pedal more play and feel. It's awesome Big Rotor Kit Question - ADBZ Matt - 12-21-2010 Want more feel on the HB not FB... Want to go big rotor , but need some info... Big Rotor Kit Question - J Blox - 12-21-2010 doesn't feel much diff to me.. Big Rotor Kit Question - ROWDY - 12-21-2010 U wont get anymore "feel" out of a big rotor kit. Change ur HB mastercylinder for that Big Rotor Kit Question - ADBZ Matt - 12-21-2010 Quote:
Big Rotor Kit Question - ROWDY - 12-21-2010 Yea so? which one?The feel is all in the master. 13mm has the squishy feel with a ton of bite, but u really cant drag a 13mm and be as smooth w a single 4 piston setup. A 16mm on the other hand u can drag smoother, but doesnt have that inital effortless bite as much as the 13mm will. I switched to a 16mm Billet on the Kawi and I like it. Big Rotor Kit Question - ADBZ Matt - 12-21-2010 Quote:
Big Rotor Kit Question - MiNi GuineA - 12-21-2010 Quote:
the 636 is the same main with different caliper brackets, the up grade is like 234 on the site Big Rotor Kit Question - ADBZ Matt - 12-21-2010 Quote:
