Canon T2i 60FPS - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Videos and Reviews (https://stuntride.the-nags.com/forumdisplay.php?fid=10) +--- Thread: Canon T2i 60FPS (/showthread.php?tid=20901) Pages:
Canon T2i 60FPS - Brandon L - 08-12-2026 slow mo is always sick...... looks good Canon T2i 60FPS - StreetLifePrez - 08-12-2026 Quote:
Canon T2i 60FPS - j_dane - 08-12-2026 ^ I was doing the same thing ur doing when I use to edit using Vegas Studio HD plat. It would freeze up while I'm editing HD vids. That's because you are running low on virtual memory because HD vids take up a lot of memory. I pretty much gave up because I always lost work and didnt wanna start over. The solution to my/our problem is using Adobe Premiere because it has a Mercury engine that can handle HD Vid editing, hope that helps. Canon T2i 60FPS - SKETCHY - 08-12-2026 http://vimeo.com/channels/tlsm4beginners some useful stuff on here
Canon T2i 60FPS - j_dane - 11-24-2010 So I was messing around with Canon T2i's 60fps and this is what I got. Now how do ppl edit with more FPS? Ive seen some do 1000fps Canon T2i 60FPS - Shane636 - 11-24-2010 I dont know anything about FPS, but thats a clean f4i. Canon T2i 60FPS - krazykyle85 - 11-24-2010 love the slow mo. sick Canon T2i 60FPS - Nascency Chris - 11-24-2010 just take your 60fps footage and dump it into a 24 or 30 fps timeline... then learn about speed changes and time remapping... cams that records 1k fps are sick but be ready to invest 100k for one... some of the xdl stuff shot last years was 60fps because it was 720p... currently there is no standard for 60fps in 1080 60p... i will tell you if you take your 60fps stuff and drop it into a 24 timeline and increase the speed to 213% it will play regular speed... Canon T2i 60FPS - j_dane - 11-24-2010 ^sounds complicated, is there a tutorial on youtube on this? Canon T2i 60FPS - j_dane - 11-24-2010 ^^ ^^^ Thanx
