F4i dogbone problem - Printable Version
+--- Thread: F4i dogbone problem (/showthread.php?tid=19955)
F4i dogbone problem - ADFreestyle - 10-29-2010
I just installed the Naarden SL200 suspension link on my f4i, went fine
Now Im trying to lower my friends 01 f4i for him... I cant get the dogbone off, its stuck on the lower sleeve/ bearing.
My first go around went smooth and it fell right out, this time its like that sleeve inside is a tad too big for the gap its been given and i cant get the dogbone to drop down.
ANY IDEAS???
F4i dogbone problem - i_throw_nickels - 10-29-2010
Quote Originally Posted by ADFreestyle
ANY IDEAS???
wd40 or pb breaker take a shit and come back, it should be loose
F4i dogbone problem - =BLEE= - 10-29-2010
Do you have weight on your suspension,that could be makin it hard to remove?
F4i dogbone problem - Naarden - 10-29-2010
Youll have to work it back and forth while prying on it, what happens is the steel inside piece sometimes rusts and rust expands, since its such a tight fit to begin with now its really wedged in there so you really gotta put some serious ass to it. Mine needed a little prying to get it out.
You can also unbolt the 3 bolts down their connected to the engine if you have to.
Unbolting it did the trick, thanks Naarden ur the best thing since sliced bread.... oh and u were wrong, only 2 bolts
F4i dogbone problem - Naarden - 11-01-2010
