03-05 r6 common problems - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Help and How To (https://stuntride.the-nags.com/forumdisplay.php?fid=12) +--- Thread: 03-05 r6 common problems (/showthread.php?tid=16469) |
03-05 r6 common problems - BLEED - 07-15-2010 so what are some of the common problems that people are having wit the r6. i love my r6's. 03 & 05. but rocking the 03 now since i picked it up. but sometimes it want to run like crap like studder and when i started on the 05 it wants to do the same thing. what are some common problems people are having. i'm thinking its the coil packs like people were talking about. but just didnt know. post up any/all problems and how you fixed it. thanks 03-05 r6 common problems - reds919hornet - 07-19-2010 mine starts skipping when it gets hot after a long ride. just let it cool down some for now. the regulator went out last year and i put an aftermarket one on it. then in the spring it quit charging again. i checked and found the plug at the regulator melted. cut out the plug and wired in a new plug and seems fine so far but have not got to ride much since i done that. that is the only problems i have had so far.
03-05 r6 common problems - $Evan$ - 07-19-2010 everything
03-05 r6 common problems - reds919hornet - 07-21-2010 sorry bleed looks like r6 bikes are the best ever made and me and you are the only ones to ever have any problems. it is great to know that for the most part they are trouble free.
03-05 r6 common problems - sQuiD FigHTer - 07-21-2010 05 allll day!!!! ![]()
03-05 r6 common problems - Isaac - 07-21-2010 Yamaha = GARBAGE I'll never trust another yamaha. I had an 07 R6. Only 3000 miles and the motor took a complete dump. It fried my cylinder head, camshafts, lifters, and needed 13 of 16 valves to be reshimed to correct out of spec compression on every cylinder; not to mention impossible starts, loss of power, and the famous yamatick that nobody will ever find out what it truly is. Oil pressure would not hold to the factory spec of 11.6 psi and dropped to 5psi. Perfect oil pump, nothing in the strainer. Internal oil passage leak/defect. Racing they blow crank rod bearings, and riding them regular your looking at a shredded cylinder head due to oil pressure issues... Fly by wire is stupid as heck and the bike rode like dog sh-t......Not good bikes at all. Dont believe me......do research and you'll see for yourself. Ride Honda! 03-05 r6 common problems - BLEED - 07-21-2010 ^^^all that is called user error lol jk. but 03-05 its the hotness. but shit what bike dont have problems. yea we are currently trying to see if its my timing cause it took a pretty nasty drop a couple of times. 03-05 r6 common problems - !!A2K!! - 07-21-2010 I know a way to make the cpu think that the bike is running coller and will run better.....Ill post it up later im at work. way to much to type. I havnt done it becuase I have no problems with mine 03-05 r6 common problems - BLEED - 07-21-2010 ^^^ok word. and now you just jink your self to have problems lol 03-05 r6 common problems - !!A2K!! - 07-21-2010 I dont care I just ride the damn thing![]() I have a cracked head and bent frame.....cant get any worse. I need a head btw lol |
