01 f4i no spark - Printable Version
+--- Thread: 01 f4i no spark (/showthread.php?tid=13220)
01 f4i no spark - vegasrider2005 - 04-05-2010
changed the key switch, not that
checked all fuses, not that
what else can i look for?????
01 f4i no spark - NME - 04-05-2010
Do you have injector pulse? Some hondas use one power wire to run a few things and coils and injectors are one of them. Oh! It also runs the fuel pump. Is it priming?
yup primes good
01 f4i no spark - tonyf4i - 04-05-2010
pulse generator! its behind your right side engine case.
01 f4i no spark - loogie - 04-05-2010
+1...also pull apart EVERY plug/harness and check for moisture/bent prongs/loose connections then go from there
ok be back in a few
ok dont know if this will help but i just pluged in the gauge there is the neutral light and a red light, under that the oil light is blinking. any ideas???? and how do i check the codes???
01 f4i no spark - COTE - 04-06-2010
ok, i have no spark...very minimal voltage to my hot side of the coil and no ground on the ground side, however i have .4 ohms of resistance from the coil ground to ECU ground...stator checks good continuity and good output...i think anyone know what the spec is for stator output on this thing?? also from what i said does this bring any sugg
