CRF50 Big Bore Exhaust Help - Printable Version
+--- Forum: Female Stunters (https://stuntride.the-nags.com/forumdisplay.php?fid=92)
+--- Thread: CRF50 Big Bore Exhaust Help (/showthread.php?tid=12597)
CRF50 Big Bore Exhaust Help - StuntBlondie - 08-13-2026
\r\n \r\n Why is this in the female section?\r\n
CRF50 Big Bore Exhaust Help - Megan - 08-13-2026
\r\n \r\n \r\n
\r\n Originally Posted by redden13\r\n View Post\r\n
Put in the TB Stage 3 Big Bore Kit into my 09 Fiddy. Still cuts out quite a bit even after jetting it. I was told to purchase a new exhaust cuz the stock exhaust just doesn\'t cut it with the new internals and bore. Anyone got good ideas for an exhaust? Looked at bbr and chp, someone has also mentioned fmf.
There is a section all about fiddy\'s take this question over there pretty please\r\n
CRF50 Big Bore Exhaust Help - OwnAgE - 08-13-2026
\r\n \r\n he wanted to know from you girls on how you got your 50 running after a big bore kit lmao\r\n
CRF50 Big Bore Exhaust Help - StrictlyStunt - 08-13-2026
\r\n \r\n put a bigger carb on it... stock exhaust will work fine.\r\n
CRF50 Big Bore Exhaust Help - DIMA - 08-13-2026
\r\n Originally Posted by StrictlyStunt\r\n View Post\r\n
WRONG you will over heat the head...
\n i\'m running a BBR D-section and its just bad...
\nno matter what is said, you need a 23-25mm carb. oil cooler and some kind of free flowing exhaust...ohh yea and a smaller sprocket in the rear..
\nand yes Someone should like move this to fiddy section hahahaha\r\n
CRF50 Big Bore Exhaust Help - redden13 - 03-17-2010
Put in the TB Stage 3 Big Bore Kit into my 09 Fiddy. Still cuts out quite a bit even after jetting it. I was told to purchase a new exhaust cuz the stock exhaust just doesn't cut it with the new internals and bore. Anyone got good ideas for an exhaust? Looked at bbr and chp, someone has also mentioned fmf.
