2013 636 AJBsays Build - Printable Version +- Stuntride (https://stuntride.the-nags.com) +-- Forum: Stunt Discussion (https://stuntride.the-nags.com/forumdisplay.php?fid=4) +--- Forum: Projects and Builds (https://stuntride.the-nags.com/forumdisplay.php?fid=104) +--- Thread: 2013 636 AJBsays Build (/showthread.php?tid=44797) |
2013 636 AJBsays Build - Righteous 1 - 04-06-2013 +1 ![]() ......and then grab those clamps, throw 'em in a box.....and take 'em to the post office on Monday!
2013 636 AJBsays Build - DicksCustoms909 - 04-08-2013 If you need your tank done i do custom tanks, my name is Neil at Dickscustoms, contact me here or on facebook.com/dickscustoms.neiltanks6.jpg 2013 636 AJBsays Build - Stubbz63 - 04-08-2013 his tanks already done, on previous page. 2013 636 AJBsays Build - stuntmydirt6 - 04-08-2013 this thing is saucy... i missed what 12bar you are running (its like an entire subframe/12bar) you called it a cheater bar 2013 636 AJBsays Build - ajbsays - 05-29-2013 so finally had this beast at the lot and let me tell you shes smooooooothhhhh,,, didnt get any action pics yet but soon to come! 2013 636 AJBsays Build - KYD - 05-29-2013 Stubbz has video on his phone with Cisco on it turning O's 2013 636 AJBsays Build - lucky13 - 05-30-2013 I got to ride it and man is it a sweeeet fucking ride the front brakes are amazing one finger on that lever is all I would recommend that's for sure. the power is amazing and smooth I'm not a fan of tailsavers but this one seems well built for sure all in all beautiful bike 2013 636 AJBsays Build - Tough Luck - 05-30-2013 AJ i finished my sumo last night that under tail was a bitch and some more tunning is needed but hey. I was gonna ask you it seems like the 50 HB set up is weak with the magura 13mm it barley wants to slow it down just idling with both wheels on the ground any idea why? or just more bleeding? Also did you have any issues if you over filled the brake resi? 2013 636 AJBsays Build - Stubbz63 - 05-30-2013 ^^ That all depends on what resy you use. mini resys cant be overfilled but a stock type usually can be. i always ran R6 rear brake resys and they work great filled to the brim and overflow when cap is put on. 50stunt dcb sucks but you got air in it or something for sure, i ran mine to a 16mm billet magura and it was fine, deff not lockup power but worked ok for me for death spins wouldnt take much to overpower either of them tho i had FTI dcb then went to 50stunt and wish i stayed FTI cuz it was stronger by a lil. with the 13mm that shit should be pretty strong. only time i didnt trust mine was for HC coasters, tho spreader coasters i had no problem with. Undertail isn't hard just takes a little time to get it all set right. I want a 450 sooo bad. 2013 636 AJBsays Build - loogie - 05-30-2013 Dude wtf you guys are high as fuck the 50stunt DCB to a 13mm Magura is bawse status I've got one finger lockup at speed and the confidence to do fast foot drags all day long! |
